Nord lock washers
AWD-Tony
6,787
3,746
Sep 11, 2017
Cincinnati, Ohio
Does anyone run nord lock washers on their turbos? Thinking about getting them for manifold bolts and O2 housing. Currently have the oem conical washers and standard FP hardware for manifold to head. They tend to loosen up after a little driving.
Stud the 4 bolts on the turbo and the o2 housing. You'll benefit two ways:
1) The nuts don't come loose
2) You'll never need to worry about breaking bolts off in the turbine housing should the turbo need to be removed for any reason.
That’s not a bad idea. Thanks Jus! Might grab these lock washers for manifold to head then.
I use normal conicals (non oem) on my turbo and o2 but i am on stud and nut i made for it. Nothing come loose
I have nord locks on my calipers as they came with them and certainly do have a good amount of resistance when undoing them. So they wont come loosr once done up, not in a car anyway
My car is strange I dont even use washers or anything. Just the bolts and I usually check once a week and so far its been holding torque for a month. I do like the idea of going all stud though. It may make removing the exhaust manifold more annoying though.
Interesting.
    • Sdcryan1
