New valve spring compressor that might work
zachakagoat
1,154
6
Feb 7, 2003
Prairie Grove, Arkansas
I was lookin around on google and came across this valve spring compressor and thought that it just might work. What does everyone think? this would allow you to access the valves without removing the head.
Well it might not work because of the valve angles and bot pattern to mount. But it sounds like a good idea for someone to make for us DSM guys :sneaky:
The thing I don't like is this that was taken from the site "Simply remove the plug and pressurize the sleeve with 100 psi air to keep the valves in place". Despite whether the cylinders can take 100psi, who actually has a spark plug hole adapter for their air compressor? It would be easier to manually feed in rope (yes it works).
I emailed the seller and asked if he had more, and also the distance between the bolt holes. It will definately be something that can be tried out I am waitin to see more information from him.
I'll keep yall posted.
Cylinders can obviously take 100psi, since cranking compression alone is 160+psi.
Also, many compression testers use normal air fittings and can easily be used to put air in the cylinders, I do it all the time as a form of leak down test.
"Designed for Honda V-tech heads b18 & b16", so no, it won't work on a DSM.
Holy crap, that design makes me tired just from looking at it. How long do you want to spend on compressing the springs?
Well, for those who can't pop the $30 for Moreso MOR-62385 (below), there's always a broken spark plug, piece of pipe, Milton adapter and a couple of quick welds.
Autozone is where I got my fittings for the spark plug holes. I think they were @ $2 or $3 bucks each and they had both sizes available (large and small plug fittings).
I like the rope method as well, but the air-hold fittings do work and are easy if you have a compressor. It does not have to be a big compressor either, Mine is only a 5gal, 2hp Hitachi and works well for me... :dsm:
Most people will say the Miller tool but you can get this tool (http://www.thetoolwarehouse.net/shop/SP-91400.html) which is basically the SAME thing but a universal model so it can be sold easily afterwards. It does require you to put constant pressure ont he spring while messing with the keepers but if you have a hand to help you it will save the 120$ more that the miller tool cost. I was just looking for something that could possibly be made at my local machine shop and the one I posted that is for a honda may be something for me to look into having the machine shop make.
i just use the normal pneumatic spring compressor, i just needed to make a 3 inch long fitting with a notch on each site and welded it to the end to make it work. paid 100 for the spring compressor and made the adapter in like 5 minutes.
Links to where you can buy those two kits above? Anyone think the one on ebay posted can take off beehive springs? It looks a little to big to fit around a beehive retainer.
Here's a nice valve spring compressor I found being used at a Hyundai service station. Mounts without any tools, access 4 valves at a time, comes with an air check valve and an automatic retainer lock installer. One pull and you're done. Makes the job effortless without pulling the head. Although not yet available in the US, it only cost $80 and works on practically all DOHC heads.
EDIT:
They have an english website now.
Sanucartools - automobile repair tool, timing-belt, patented product
I think I speak for everyone when I say "WHAT THE F@#%!" Want to find one and sell me one? Holy crap that thing looks like a beast.
If it's not available in the US it can be shipped here but seriously there has to be something here like that.
What's the brand name? Surely I can find the manufacturer on the net.
Nah. If those were here, we'd have heard of them. Nice that it not only centers by mounting in the spark plug hole, but that it's also set up to pressurize the cylinder to hold the valves up.
OMGI want one.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
