New set up for 2006
nikkeebabee
253
Jul 21, 2004
Rochester, New York
hey folks,
I just thought I would share my set up for this year and see if there is anything I may be missing or just general imput on it.
FUEL
cozmo pump
aeromotive 1:1
s-afc
fic 650s
ss feed and return lines
TURBO
Bullseye V-Trim (25 psi)
Slowboy Fmic
Tial bov
Dejon Tool Intake
Slowboy Crank Pulley
02 dump
Vrs 3" Turbo back
I'm also running a Slowboy 3500 clutch kit.
Anybody have any imput on the bullseye turbo specifically? I got a hell of a deal with it and was wondering what people have thought of it.
My plans are high 11s traping at roughly 118-120ish
car is awd by the way:rocks:
Might want to get something other than that safc to tune with. Get dsmlink and it will make yours goals much easier to get to.
That will get you to your goal... I would say that the turbo is not that great, and that is why you got such a great deal on it. Slowboy is practically trying to give them away as they overstocked thinking people would buy them :tease:
You should still be able to hit high 11s... maybe a little lower on the trap speed. Tuning IS key and what will make the setup. Put everything together, see how it runs, and get a logger. then go from there with either some cams or better tunning equip.
by the way, what is a "cozmo" fuel pump? linky?
You might also want to pick something other than a V-trim since the map on these is pretty unforgiving, making them prone to compressor surge. A true 50 trim would be a better idea, especially if you can get one with the T04E cover.
I agree as well about the AFC. It's a piece of junk for any serious tuning. Get Link and be done with it. Oherwise, it all looks good and you should have a very enjoyable street car when you're done.
Good luck,
Andy
I plan to go with dsmlink hopefully later this summer as well as maybe some fp2 cams.
So for now the afc will have to do what it can.
The v-trim will eventually be replaced with something slightly larger but for now iwll have to do.
I can't wait to get everything together.
I'll keep everyone updated on the dyno tune as well as track times
Thanks
