boost and injector size for my set up?
haywire96tsi
Dec 9, 2010
chi, Illinois
Hey everyone im looking for some input on two things. How much boost to run and what size injectors for my set up 93 octane thanks!
My mods
6bolt swap, walbro 255 fuel pump, fpr, 2mm oversized valves, ported polished head, manley h rods, manley pistons.(9:1) arp head bolts,balance shaft eliminator,cometic head gasket,50 trim turbo, 274 cams, tial wastegate and bov, front mount greddy boost control. Going to run dsm link. Let me know if you need to know anything else, Thanks again!
Run as much boost as you can in it's efficiency range while not having any timing retardaton from Knock. For injectors, since you are getting ECMLink, go with at least 1250s for future planning with a larger turbo and for E85 use. 1600s would be a solid choice as well as you can always tune them down to idle like stock.
Thanks, for the input i was off i was thinking 1000cc.
If you're not thinking about switching over to E85, 1000's are a good choice. That's the issue I'm having. Theres an e85 station within walking distance, but sometimes they don't have any for weeks at a time, so I'm sticking with pump and smaller injectors.
Yea im not planning on runnning e85. Thanks for the input.
