injector size
turbobird92
127
Jan 28, 2003
can anyone tell me what size injectors i will need to runn about 22-25 psi? my other supporting mods are front mount,safc 2,maft, i want to know so i can have eprom chip burnt.it is for a hx-35 with bullseye turbine housing also 3" turbo back exhaust
Doesn't really matter if you're getting a chip, 850 should be sufficient but you should go bigger in case if you decide to upgrade later.
I have people running 25 psi on 680's tuned on a GM mas and DSMLink. Zero Knock on 104
