2G Need help. Replaced master cylinder and 1st and 2nd gear have slop and pop out
Nicg
May 30, 2022
Port orchard, Washington
I recently replaced my clutch master cylinder and replaced the clutch line with a ss braided line from the master to the slave and deleted the accumulator. I bled the system real good and adjusted the master/clutch all gears work and I don’t notice any grinding or anything and clutch pedal itself feels great. However when I hit the clutch pedal I can hear the slave make a weird sound and 1st and second gear have slop. Whenever I’m going down or up an incline it will pop out of gear. I’m at a loss as I adjusted everything accordingly and I’ve done plenty of research and cannot find anything on this topic. Previously to the repair none of this happen not even the sloppy feeling in the shifter. I’ve messed around with the adjustment and it’s the same thing. I looked at the linkage and everything is in good condition. Has anybody ran into this issue help is needed
Are your shifter cable casings bolted onto the tranny properly?
Other gear popout possibilities:
What was the purpose of replacing the MC and lines?
The symptom you described isn't a clutch issue. It's a trans, shifter, or linkage issue.
I replaced the master cylinder due to it leaking fluid in the inside of the car and inconsistent pressure in the pedal. It’s never done this before so I’m very confused. I’m reading the threads you guys have sent
