Need advice on which turbine housing to get
50trimmed1g
262
Dec 25, 2007
Orange County, California
Hey guys. Long time no post but I have a question. I have a PTE 5031 with the stage 3 turbine wheel and .63 ar dsm bolt on housing. I will be putting on a turbonetics T3 manifold and I need to get a new turbine housing because my 50 trim is running a mitsu housing. Is this what I need?
T31 Exhaust housing for StageIII (76 trim) turbine wheel : atpturbo.com
Or can any of you recommend anything better I really appreciate it. Also, should I stick with the .63 ar when I get the T3 housing, Or should I up it to the .82? My main goals with the car is to run an E85 setup, no more than 26 PSI and use it as a daily driver/rice killer. Thanks in advance guys.
what exhaust bolt pattern are you looking for.i have a t3 .63ar with a 4 bolt exhaust that will work on your turbo.you can get it for a good deal
PM sent.
Anything larger than .63 is probably overkill for a 50-trim compressor and T31 turbine unless you're running a stroker.
I do know of a DSMer who ran a .82 housing on his 60-1 / T31 turbo and it was rather laggy but was a completely different animal in the upper RPM range that it was with the DSM bolt-on housing which was installed prior.
    • Sdcryan1
