N/T Boost Levels
aspekt9
344
4
Dec 25, 2005
Boston, Massachusetts
What is preventing me from running 15psi on the 14b with the given mods in my profile on my N/T to turbo swap? I know detonation is the determining factor so what can be done to minimize it to the point where I can run a decent amount of boost?
I second that. I don't know about how the internals vary on a nt vs turbo, other than no oil squirters, but that's not a big deal. What I can do is some math for you, to help paint a picture.
1g NT= 9:1 compression
1g Turbo= 7.8:1 compression
So the NT is 1.154 times more compressed. So running 15psi would be more like 17+psi. And as far as I know, 17psi is starting to push it on stock internals, especially if you don't have the supporting fuel mods.
I guess, if you figure you have the same mods as a guy running a turbo 2g at 17psi, then you'll be ok.
Is a good tune and timing control the key to control detonation? I've heard the N/T pistons with the higher ring lands can handle the power fine it's when detonation occurs that they crack and blow up.
The thickness of the amount of metal between the piston crown and top ring groove are different between the non-turbo and turbo cast OEM pistons. If you run excessive boost on stock cast non-turbo pistons, they will break.
http://www.dsmtuners.com/forums/420a-turbo-conversion/141210-non-turbo-pistons-cant-take-boost.html
Higher compression Pros:
- More off-boost torque.
- Less turbo lag due to increase exhaust energy.
- Less boost required to achieve the same horsepower as lower compression.
Higher compression Cons:
- Higher octane fuel required to prevent knock.
- Lower peak boost threshold without PERFECT tuning.
- Water / Meth injection use almost mandatory to run over 20psi on pump gas.
dude if i was you i wouldnt go over 10 psi.id run 8 at most.thats a safe level now if you run meth and or race gas id say 10-15 psi would stll be iffy.now if you dont care about ya motor run ova 10psi but have a wreaker on speed dial man trust me.maybe a lil nitrous would get you that lil extra power you need.
I can't input about stronger ring lands, but concerning detonation-
Tuning and timing does control detonation, but it does only go so far. Read this first:
explaining knock and how to get rid of it
That will give you an idea bout what detonation is, what causes it, and what prevents it. You mentioned timing is a key. Well increased timing can increase power, but eventually it will create detonation. Same with boost, more boost = more power, but it eventually leads to detonation.
Hope that all helps.
I would say 7-9psi for 91 pump. I have run 13psi with no problems on 100 octane and turned 14.0 at the track. It ran great till my boost controler malfunctioned and spiked to 21psi & spun two rod bearings and broke all four piston's ring glands on my 1g 7 bolt.
