My "Street Car" Build!.
sbengineering
188
3
Jul 30, 2003
Blackwood, New Jersey
Lets see some more pics of everything! And how about them different techniques not normally seen on dsms ;) I'm in the process of stripping and sanding my engine bay.
No Balance Shafts
Gyptol coated
JE Pistons (.020 over)
Eagle Rods
ARP main and head studs
everything balanced
Gapless rings
Copper head gasket
ACT flywheel
BC cams 272 cams and springs
bronze guides
manley valves Stainless steel valves
3G lifters
Fidanza cam gears
DNP header
Copper Exhaust gaskets
T67 Turbo. Thats most of the engine stuff.
Battery is in the trunk
rewiring of front of car
S&W 8 point cage
Modified rear bumper
and lots of detail
Tell me how you are bending those lines and where did you get them. And where are you tucking your wires?
James :laser::talon:
The lines are the stock ones. The harness is also still stock, mostly. I trashed all of the emissions. I took the fuse box and the main link and ran them into the glove box. I had to lengthen every wire; with the help of the factory service book it wasn't that bad. I ran the wiring inside the passenger wheel well, then through a body plug, and then right into the glove box area. I then cut a hole on the firewall next to the shifter cables so i can run engine wires back out to the engine compartment.
Everything works like its suppose to, it is just all hidden. ill take a few photos tomorrow and post them.
Looks good, but that clutch master cyclinder is a little discolored, gotta replace it!
No Balance Shafts
Gyptol coated
Eagle Rods
everything balanced
Gapless rings
Copper head gasket
ACT flywheel
bronze guides
3G lifters
Fidanza cam gears
DNP header
S&W 8 point cage
and lots of detail
I just saw you have a S&W roll bar I ordered my 10 point from them how did yours fit?
Im really lovin that set-up, its ###### the cleanest stripped car i've seen...LOL. Im trying to get mines like that but i do hava question tho, what sizze bolts did you use for the headlight motor assembly? I had to buy new headlights and they didnt come with the bolts and i lost the ones to my car.:dsm:
That engine will be a beast on the road. Everything is clean and done right. I Can't wait to see the final results.
