My "Street Car" Build!.
sbengineering
188
3
Jul 30, 2003
Blackwood, New Jersey
Your going to have to post how you actually did the wiring, I might want to do that too. So basically your car has none of the emissions at all?
Yeah im in the process of getting a weld-on roll cage. Some say bolt-ons are better but thats just peoples opinions. Either way i'd take either of them.:dsm:
You realise you don't need one till you go over 135mph or 10.99 for a full cage and 11.5 and I think like 12xmph for a roll bar(cage minue the halo and windshield bars.
I dont paln on running 10's so i think an 8-pt will be good. I just wanna run 11's for now and maybe in the future i'll hit 10's. But I need to strip my car like sbengineering did, das da best way to work on a car.:thumb:
Car looks clean as hell, except one thing. Those welds look boogerlicious :nono:. Roll cages are there to save your life, please don't rely on welds like that, they look rather scary. That side bar to main hoop weld would not pass inspection from any competent tech. Other than that, dead sexy :thumb::cool:
Yeah to the OP did you weld this yourself? I am local like I said I can come check out yoru welds and let you know if they will pass at ATCO cause I know that's where your gonna end up going when it's done. I have a hook up with a guy that welds around here I can get him to hook you up too if you want. I work for South Jersey Auto Supply I was actualy at our blackwood location today and i'll be back there monday. One more thing it doesn't look like you used plates at the bottom of the main loop bars or the support bars def not a good idea:(
Where in blackwood do you live. I'm moving into the washinton way apartments next Sat would def like to come by and see your setup in person and I have a digital camera I can help you take some pics since you seem to have shakky hands LOL.
my shop is in west berlin, off of 73.
This was my first cage install. So i hopefully can only get better. Those booogers were on the third pass though. You think that will still be a problem?
BTW, i will get pictures up of the wiring this weekend. I had to do some traveling for work, so i haven't been around much.
The plates are there, i formed them to the crossmember (not the floorpan), so they are a bit hard to see.
Spaghetti Engineering, we are a design consulting and R&D company for the aftermarket.
Aftermarket automotive ? Hmm interesting never heard of you guys and I deal with everyone around this area. I work for South Jersey Auto supply we deal with everyone wholesale in the area and a little retail. Our location by you is right behind walmart on 73.
Main fuse block and fuse box is in the glove box along with two breakers for adding on things.
All engine control wires enter through the firewall near the shifter cables. This keeps pretty much all stock wiring that is needed, and still allows me to have almost zero wires in the engine compartment.
I'm a lil late in joining the conversation but i love the fuse box relocation, anymore pics of the wiring set up. I'm getting ready to go thriugh the majority of mine and clean it up so to speak and i was thinking of hidding my box it the glove box area, was it a pain in the butt to do?
Main fuse block and fuse box is in the glove box along with two breakers added for 12V power and 12V ignition power.
I had both the main front harness out of the car. i got rid of anything i didnt need, (i.e. emissons). I then lengthed the front body wiring and ran them from the glovebox, through the existing passenger grommet in the inner wheel to the front of the car. I then cut a hole in the middle lower area of the firewall and ran all of the engine wiring through there. This keeps all of my engine wires right behind and below the intake to keep things hidden the best they could.
