We're on Boost
- 3,135
- 1,539
- Aug 25, 2007
Seattle area,
Washington
Update, Still running great! Thank you Gary and everyone else that helped.
Today I did a full send pull as i watched the gauge. For sure pegged the gauge at 20 psi and I could feel it like start to break up so I got out of it as soon as it stopped being smooth.
Definitely gotta get a lower boost level so I will get the vacuum lines re ran and won't use the T that's in it now.
Sounds good. Yeah the wastegate hose should go to the turbo outlet, and the BOV hose should go to the intake manifold. Two separate hoses, not Teed to each other.
The wastegate hose, you don't want it to get blown off of its connection because if that happens you lose all the air pressure to the wastegate and then all of a sudden you have maximum boost instead of minimum! So that hose should be tied on at each end with a nylon zip tie. I mean that's the simplest way. Most kinds of hose clamps don't work right when they are that small because they don't stay round enough. The small clamps I know of that do stay round are called Corbin clamps. They are spring steel. They should be ok, but you'd have to fool around with finding the right size. Nylon zip ties are easy. My car has nylon zip ties on the small hoses and it's been ok. Oh I see you have a black zip tie on your wastegate in the current setup. Like that is ok.
In a couple days here I'll cook up some reduced timing numbers for those low-LoadFactor areas where you had some knock in the last log.
What psi does your boost gauge scale go up to? Does it end at 20 or does it go higher?
