Archer Fabrications
- 9,719
- 706
- May 9, 2011
Scottsdale,
Arizona
Hi everyone, i just wanted to start a thread to document my second 4g63 tear down, but first tear down on my built race motor.
A little background:
Motor was built about 2011/beginning of 2012 and built very well by my friend jack who is a member on here but doesnt freeqient anymore. Anyway the motor has been kick ass, i choose a scat/mahle 9:1 combo on a stock crank and a .020 over bore. We used ACL race tri metal bearings for thr mains and rods, and had all ARP hardware. 14k miles later and a move to scottsdale arizona, all is great on my 6466 pushing about 38psi on e85 and things looked awesome on the tune, i was on the highway hitting a 3-4th gear pull when something popped and started smoking, oil pressure hit 0. Now i wasnt positive that was accurate in the moment due to almost hving yhe crank pulley cut the sensor wite off. But had to drive 10 minutes off the highway to get to a safe exit and place to park to examine the damage, turns out my magnus oil filter backed off leaving all my oil on the highway, by the time i got to my parking spot, the motor was knocking i knew it was done. Ive changed my oil every 750-1000 miles with valvoline conventional 20w50 And the last time i had added the magnus billet oil filter. Lesson learned, keep to the good ol' oem 92 filter, or a wix filter only for me. I'll never use the magnis billet filter again. So fast forward 4 weeks and pulling the motor and sticking it on the stand, pulling the oil pan and inspecting the bearings, here is what i find.
A few gold flakes in the pan, not mich was in the oil filter it looked pretty clean bit so did the oil pick up and mostly the pan as well.
The rods werent blue and what i can see of the cylinder bores they look alright too.
Heres what the rod bearings and crank journals look like
#4
#4 rod journal
#3 rod bearing is bad
#3 rod journal is good
#2 rod bearing is bad too
#2 rod journal is good
#1 rod bearing is good
#1 rod journal is also good
Now here is the fun one, here is the center thrust main bearing
Heres the journal which looks good
And the accompanying bearing
I havnt pulled the other main bearings yet, I'm not sure what to expect. This is far as ive gotten so far. I plan to re use the crank, probably upgrade rods and pistons and clean the block and head while I'm at it. Considering the crank still looks new id say the bearings did their job very well and i wont heaitate to use them again. What would you giys do next if this was your motor?
My current goals are 850whp with the 6466 on e85 and or 150+ mph traps and 9's. Looking to bulletproof the motor to be good to handle 1000whp. All input is appreciated.
#4
#4 rod journal
. Can't wait to see her back running again!
