Mighty Max SOHC g63b to DOHC 4g63 head swap
ZZZ0MG
Nov 19, 2025
raleigh, North Carolina
I own an 87 mighty max with the g63b and I've been wanting to put the dohc 4g63 head on for an N/A build. I plan on making/finding an intake for two Weber 40/45 DCOE sidedrafts so I can keep it carbureted, my biggest issue is the ignition system. Is there a way I can do the ignition without an ECU? and is the swap even possible?
is it possible to run a distributor with a DOHC 4g63? if so, which and how?
Possible if you can figure out a carburetor for it.
is there a way to use the OEM 1g ignition with a standalone ICM or an ECU just for the ignition, since my truck doesn't have one.
I don't know if the distributor from the 4G37 would fit or if you'll have to make something.
I did a little search and the 4G37 is a no go. I couldn't find anything that looks like a direct swap for a 4G63 DOHC head without modifications. The closest I came was a MD314946 T2T56071 but it looks too deep and is missing the oil seal o-rings. Beyond the physical issues its not clear what you would need to do to charge the coil.
There are a bunch of start people here but what you're looking to do is way outside our norm. Running injectors with ITBs and a NT ECU would be more likely to work.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
