2G Low Coolant Level Sensor fix
Lintu
40
38
Oct 29, 2025
São Paulo, South America
Hello guys!
Just wanted to share how I fixed the Low Coolant Level Sensor on my 1995 2G Eclipse GS-T.
Symptoms
- Car came with the Low Coolant Level Sensor unplugged
- Plugging it in would immediately trigger the Radiator Warning Light
- In practice, the sensor was non-functional
Preparation
- Remove the coolant expansion tank (disconnect the sensor if needed)
- Drain the tank
(I saved the coolant in a clean bottle and reused it afterward)
Removing the sensor
- The sensor is held in place by a rubber bushing
Carefully pull the sensor out using pliers
⚠️ Do NOT squeeze the plastic body
- Since the rubber is ~30 years old, expect the bushing to fail
(mine did — more on that later)
- With the sensor removed, take the opportunity to clean the expansion tank thoroughly, inside and out.
How the sensor works
Despite the name, this “sensor” is really just a simple magnetic switch:
- A plastic cylindrical buoy slides up and down inside a hollow plastic shaft
- The buoy contains a magnet seated in a recess
Inside the shaft there is a normally-closed reed switch
- As the coolant level rises or falls, the buoy moves and the magnet opens/closes the reed switch
- A clear plastic cylindrical cover protects the assembly
- Two wires exit directly from the reed switch at the bottom
Simple and elegant.
Pre-test (before disassembly)
- Turn the sensor upside down and right side up. Make sure the buoy moves freely inside the shaft
- Check continuity across the two sensor wires:
Sensor upright > continuity
Sensor upside down > no continuity
Electrically, mine was fine — so I moved on to mechanical testing.
Sensor disassembly
The shaft tip is plastic-welded to the outer cylindrical cover
- Use an exacto knife to carefully break the plastic weld at the top
⚠️ Leave enough material so it can be melted back later
- Slide the outer cover off
You’ll now see the buoy — note its orientation
(It can be installed both ways, but behaves differently. Magnet side goes UP.)
Floating test
- Drop the buoy into a glass of water
- It should float
Mine didn’t 😅
Fixing the buoy
- I punched a small ring out of anti-static pink foam (electronics packaging foam). It has air trapped inside, so it should help with flotation.
Outer diameter = buoy outer diameter
Inner hole = buoy inner diameter
- Pressed the foam ring into the magnet recess of the buoy
- Re-tested in water → the buoy now floats ✅
Functional test
- Temporarily reassemble the sensor
- Place it in a glass of water
As the water level rises:
- Buoy moves up
- Continuity across the wires changes accordingly
Sensor fully functional again.
Final reassembly
- Reinstall the buoy and plastic cover
- Melt the tip of the plastic shaft back into the cover to lock it in place
Since the original rubber bushing failed, I:
- Sealed the sensor to the expansion tank using black high-temp engine silicone
- Let cure for 24 hours
- Reinstall the tank and reconnect the sensor
Result
- Warning light behaves correctly
- Sensor works as intended
- No leaks
That’s it — hope this helps someone dealing with the same issue!
Fine for South America but most 2g's in the USA don't have the Low Coolant Level Sensor.
Well, you live and you learn!
No DSMs were manufactured here in Brazil, so mine was imported from the USA.
I found some forum threads discussing this sensor, so I assumed all of them had it...
Out of curiosity: is the 2G USDM tank sealed at this location, or is it a different tank altogether?
Thanks!
In the US, 1995 models had the low coolant sensor in the reservoir tank. So, it is applicable, but only to a small percentage of owners, unless it’s (hopefully) the same mechanism for 1Gs.
I didn’t even realize dsm’s had a coolant level sensor until I picked up a coolant reservoir from an early 95 tsi awd. I’ve had 8 second gen’s and none of them have had it 😂
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
