Link!!!!!
b00zt3d spyd3r
589
480
Feb 25, 2016
Lawton, Oklahoma
alright everyone today is gonna be a good day for me. Dsmlink will be here when I get home from work. Here's my question. Seeing that I'm a complete noob with link except what I've read and videos I've watched, would I be able to get it installed and dialed in within 1 day or should I give myself more time? The car it's going in is my daily and I plan on doing this on my day off (Friday) but if I can't have it ready to go by Saturday morning then it'll be a no go. If I can't get it in one day in yalls opinion I'm waiting till next Wednesday and Thursday
I looked at your mods and I think you had better dedicate more than one day. You could probably get the idle tune and load a stock 2g timing and fuel map, but you will need to cruise around to dial in that part and WOT will come last usually, working up to different RPM's as you go. There are a few members on here that are willing to help out and I am sure they will look at this post and chime in for more info for you. You will like Link, it is a very useful tool! I tune my own, but it has taken quite a while to get it ironed out and I am still working on one small area that gives me a fit. @GST with PSI is very very helpful on this stuff.
I looked at your mods and I think you had better dedicate more than one day. You could probably get the idle tune and load a stock 2g timing and fuel map, but you will need to cruise around to dial in that part and WOT will come last usually, working up to different RPM's as you go. There are a few members on here that are willing to help out and I am sure they will look at this post and chime in for more info for you. You will like Link, it is a very useful tool! I tune my own, but it has taken quite a while to get it ironed out and I am still working on one small area that gives me a fit. @GST with PSI is very very helpful on this stuff. Brian, are you out there???
His name is Brian too? That's awesome LOL yeah I been trying to get link since I pretty much got the car. Finally was able to. I only get two days off a week next week will be Wed and Thursday I will do it then I hopefully have a buddy coming to help but he doesn't know what his schedule will be at his job. I just don't wanna blow it up LOL
Lolz. Unless you're one of those rain man type motherfuckers, you're looking days, if not weeks or months to get proficient...And that's with good help. On your own, who knows.
No, I would not expect someone looking at Link for the first time to dial in any part of the tune in a day. I mean, it's not rocket science, and there's tons of material to reference, but it's still a decent learning curve for most.
My advice? Follow the ECMlink templates provided, post a log, get feedback, make adjustments, learn.
Rinse.
Repeat.
Keep in mind, mistakes made during the learning process of tuning have the potential to leave you poor and walking...
IT all depends on how prepared you are. I you have a good understanding of everything you need to do, you may be able to get a safe, conservative, non-aggressive (did i say safe?) tuning for closed loop driving to get you back and forth to work. By no means will WOT be dialed in or your boost turned up. Most likely your fuel trims will even still be less than ideal.
If it was me I would wait till i didn't have to go anywhere for 2 days.
Edit: I have a similar set-up, it wasn't that bad to dial in, but i did it slowly as i built the car. All at once could be iffy.
You could get it dialed in in one day, if you lived near Brett and had a case of beer to offer. LOL
When I first got link it took me at least a week of driving and logging to get a real feel for the program, it's one thing to watch the videos before you get the program, it's another ballpark entirely to have the program in front of you and be able to see the changes that you make to your idle and deadtimes cause real world changes with your car.
I'd say if you had a few hours to devote and could get wifi wherever your car was sitting so you could scroll through the websites, you might be able to get your idle sorted out.
If you bought it brand new from ECMlink it should come with your injector size, maf setup and the stock 2g maps loaded. I mean it'll be driveable.. but to what extent? I can't rightly say. Looking at your mod list, you might be able to get a rough idle/cruise tune sorted if you had a day or two of tinkering to get it sorted out, don't even think about WOT yet though.
It is brand new from ecmtuning ecu and all. Not really worried about wot pulls right off top but I have to drive to drop kids of at school and to work every day
After a basic setup, every car I tune starts at WOT. I dial in WOT, cruise, and then idle last. That especially holds true when I'm tuning cars on SD.
The main reason I do this is so I can get my global fuel values on point at WOT so they are static by the time I dial in cruise and idle.
On a SD car specifically, having global fuel set correctly will allow you to properly scale the entire VE table. If global is off, your table will either be scaled high or low depending on if the global fuel value is set lean or rich.
Long story short, I worry about WOT pulls right off the top, and that's what I'd be asking for if I were tuning your car.
When I say basic setup, I'm just looking to see if the car is in good mechanical shape. If it is, all you really need to do is post a log with a snapshot of your settings. That's pretty much all I would need to tell you whether or not your turd will blow up if you go out and beat on it. Also, obviously, ensure your boost is set at a manageable level. So long as all of the above is good to go, you can make WOT pulls to your heart's desire.
On a SD car specifically, having global fuel set correctly will allow you to properly scale the entire VE table. If global is off, your table will either be scaled high or low depending if the global fuel value is lean or rich.
When I say basic setup, I'm just looking to see if the car is in good mechanical shape. If it is, all you really need to do is post a log with a snapshot of your settings. That's pretty much all I would need to tell you your turd probably won't blow if if you go out and beat on it. Also, obviously, ensure your boost is set at a manageable level. So long as all of the above is good to go, you can make WOT pulls to your heart's desire.
Okay thanks for the info man I'm honestly a Lil intimidated by all this LOL. I will start working on it Wednesday since I have Thursday off too. I'll definitely have to learn quick LOL. I don't think it'll blow up though I've beat on it a Lil but but not too bad. LOL its on safc-2 right now and it sucks LOL. Other than it running rich it's in pretty good shape need to do a blt though I'm pretty sure I have a leak since my front bumper bottom out. Need to raise it back up about 3-4 inch
The reason I suggested avoiding any WOT tuning was because he is still new to the setup, with tuning and cruise you can make fairly drastic changes with little to no repercussions.. whereas someone new to the program making large changes to the DA tables and forgetting to zero out those same changes in the basic tab could have serious consequences.
Otherwise I agree 100%, when I switch to SD here shortly I'll probably be sending you a few logs for consideration. LOL
Yeah, agreed.
I recommend going to the last few weeks of ECMLINK threads on this site. this way you can get answer , you will probably have during your initial learning curve.
And GST is constantly schooling people on those threads, with helpful links and references.
Plus it saves him the repetition. This is valuable since he is one of FEW willing to help.
Not necessary. My cut is my right foot LOL.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
