launching rpms
Joe Ciechowski
Nov 16, 2015
Clearwater, Florida
On a stock gst 4g63t what rpms are you guys launching at? I either spin or the car falls on its face.....
First things first you need to fill out a profile of your car, FWD,AWD mods ect.... Secondly it will not be the same for everyone camshafts, turbo selection, intake manifold there are many things to take into consideration. The key is to make sure the drivetrain is pre-loaded on the launch. Is our drivetrain the greatest thing ever no, but a built transmission is essentially a stock transmission with some cryo treated parts, micro polished and different bearing pre-loads unless you go to a dogbox which the average DSMer cannot afford or is only trailering the car to the track. You really need to do some research on the subject. I was running a 82,000 mile un-touched manual transmission and snapped a rear axle after about 50 drag passes. I was running street tires and getting no wheel hop. Started at 5,000 RPM and my sweet spot for my set-up was around 7,000 RPM. But until we know what you are running on your car even engine management is a huge factor because then you have the option for 2-step launch control.
He's stock. AWD or FWD would be good to know OP
A GST is tough especially on the street where bumps and crevices in the road can kill your launch. I personally never launched GSTs for the sole fact that I knew it would be pointless. Best thing you can do is get the widest tire to fit (245-255) with a decent sidewall, some solid mounts and even a boost by gear tune when you get into bigger turbo applications. Good luck.
I was always around 3500 on street tires (hankooks), lightly slipping the clutch and lowering the tire pressure to like 20-22psi. And 5250 on the 2 step with 8-10psi boost on my qtp's (10psi), cutting low 1.7 60' ;). Definitely helps to slip the clutch just right. Seat time and feeling out your setup is really what will pay off! :) Have to have to have the right clutch setup. And depending on power level plan to break a few axles trying LOL. Terhune race axles ftw!
I have a gst and its tough to get consistent launches on street tires. Mine is always right on the edge of blowing the tires off. It makes it fun and frustrating in first gear. mine is tough to keep traction in 2nd makes me want AWD
  • For sale 4G63 3 inch fake cat converter.
    3 inch two bolt 19.5 long fake cat. Hollow inside. Flange bolts are 4.25 inch on center. Good...
  • Wanted Stock frame, Turbo manifold
    ISO: 1G DSM Tubular Exhaust Manifold – Stock Frame Turbo Location
    • Cj Anderson
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
