blackbyrd
- 718
- 23
- Jul 9, 2006
Columbus,
Ohio
Alright, I really need help on this. I'm moving across the country in a week and I'm going to have to buy a new car if I can't fix this seemingly easy problem.
After doing an engine swap in my 1G, and going to shift in any gear other than Park or Neutral, I hear a violent shorting out sound from inside my kickdown servo (used a stethoscope to pinpoint, and unplugging the connector to the servo stops it). It'll short out for about 10 seconds then stop. Visually inspecting it, I cant see the short on the outside so I assume it's inside the servo housing.
I take apart the servo cover, and I find some tranny fluid sitting in there. Well it made sense for a minute that that was the problem, but after spending nearly an hour meticulously cleaning every part inside it, the cover, the connector on the outside, it didn't seem to make a difference.
A few of my auto buddies didn't have a clue, and I'd rather not replace the servo cause the dealer wants an arm and a leg for it, and I need every dollar I can get.
Besides it doesn't make a whole lot of sense how it would go bad just sitting there for a month. It worked fine before.
Has anyone else came across this? Is there anything else it could be? Any suggestions at all?
Thanks everyone!
Thanks everyone!
