kickdown servo adjustment
92eagleTSI
133
Feb 26, 2005
Columbus, Ohio
I am doing a rebuild and I need to know what the specs for the kickdown servo are? I know the specs were in my shift kit instructions that i had installed previously but I can't find the instructions. I need this ASAP, like yesterday. Thanks
My Translab kit says
Insert .062 (1/16) drill bit in gap so servo pin cushion can't compress .
[ where pin meets the case next to band }
Air check through the band apply hole and measure pin travel with the bit in and total servo travelshould be .065 to .085 inch .(at leat 1/16 but less than 3/32 )
Hope this helps
