Is my MBC hooked up correctly?
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
My MBC is hooked up like this:
From some port on the intake manifold to the BOV. In between, the line is Tee'd into the MBC the other side of the MBC goes to the nipple on my External Wastegate.
Does this sound right? I could have sworn that this is a no-no for some reason. If it is a no-no then what sort of symptoms would it cause and what way should it be connected?
Thanks for any thoughts!
no that is wrong. the BOV line should have nothing tee'd into it; just straight line from BOV to intake manifold.
the MBC should go between the port on your j-pipe and the wastegate.
No that's not correct. I don't know exactly what it will do but I've heard others say not to go to the BOV. It should go from the turbo outlet (j pipe) to the wastegate. Which is how stock is setup with the WGS. Check here:
http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/237982-best-way-install-mbc.html
I don't know how much different Galants are designed but still the same location. I saved this link for when I get a MBC
EDIT:
Man, beat me to it. I can never get the first reply :p
like already mentioned tapping mbc into intake line at bov and intake manifold is not the correct way. If im not mistaken after a while having it connected like this will create problems with the bov operating properly.
My turbo doesn't seem to have that fitting at the compressor. It is a Big16g. The GVR4 engine bay is cramped in that area. Does that seem right? Could that be because it has an external wastegate? Not sure if that would have anything to do with that but I figure I would just draw it to your attention.
Also, what is the "J-PIPE"? There are so many different pipes that I am confused LOL.
Thanks!
Thanks is it the one at the top of the compressor held on by 2 bolts if you look right down at it? My ETS setup has some allen bolts in there and I am wondering if they will come off easy...kinda scares me LOL!
After looking at Calan's pics, it doesn't get any more clear than that!
Thanks
The J Pipe is the pipe coming directly of the compressor housing down into the intercooler piping. It is shaped like a J and is held on with 2 bolts. You can tap this pipe off and make a source. Ill try to post a picture for you.
That is a good link; I always link to that thread on questions like this.
To the OP, now you can mark this thread as resolved. Go to thread tools at the top and select mark thread as solved.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
