91dsm
- 127
- 14
- Sep 12, 2014
Perkasie,
Pennsylvania
Im going to be installing my wideband in the rear O2 sensor location. I have no intentions of using the factory rear O2 again so Im wondering what's the best way to route the wideband through the floor ? Should I remove the factory wire and dremel the hole big enough to push it through or should I cut the wires before the connector for the sensor and solder them back after running the sensor through the floor ? Also I want to connect the lc2 controller output to the ecu's rear o2 signal. Could I just connect it to the white wire that originally ran to the O2 ? Im guessing that's the same as using pin 75 at the ecu.
