Bedicine
- 542
- 189
- Jan 3, 2022
Toronto,
ON, Canada
Hello,
I've got a 2g and trying to wire in the LC-2 Wideband with a gauge and the other connection for ECMLink. I believe i have everything installed correctly but when i start the Calibration i cant get the light to go solid green (Sensor is heating up).
I have it wired as follows:
- Gauge /Controller Power from a 12v switched (back of radio)
- Ground i'm pulling from the back of the cigarette lighter as it seems to be stable
- White wire on back of gauge to yellow wire of controller
- Brown wire from controller going to front 02 sensor on ECU. I cut and soldered the wire at the ECU
- Dimmer switch for gauge is running off the cigarette lighter light
- LC-2 Controller
- ECMLink V3
- Battery is brand new Odyssey PC925
- WB gauge from ECM as part of the kit
Did i wire the brown and yellow incorrectly
- LC-2 Controller
- ECMLink V3
