impact bar bolts HELP!!
DSMnOOb00
903
4
Apr 29, 2006
FRESNO, California
Can Someone do me a big favor and tell me the size of the 2 bolts under the car that hold the impact/crash bar in place, I took them out and can't find them anywhere :sosad: :confused:
im thinking I'll just hit up the hardware store and pick some up, but I dont know the size.
thanks!
I believe he is talking about the front bumper support aka crash beam. IIRC they are M10x1.25 with a 14mm head but I cant be 100% sure
I know what bolts you are referrin to but do not have them in front of me to get the measurements.
For the front crash beam, it slides into the frame via the two metal posts; one at each end. To remove that there are a total of 4 bolts, 2 for each side that are accessed from under the car.
The same bolts need to be removed to take the bumper assembly off as the crash beam is attached to the bumper.
I hope that helps someone that currently has access to the bolts for measurement.
This one (62994B)?
If so, Redwidow has it correct. They are M10 x 1.25mm pitch x 25mm long.
