ECMlink Idle tune log...Please help
Jaydog
44
Jan 26, 2011
grand rapids, Michigan
I'm trying to dial in my idle tune still and am having problems. I still cannot log my wideband and the gauge is reading around 15.5. I have to check for an exhaust leak. Anyway, My LTFT Lo is -5.9, LTFT Mid doesn't change and the STFT is +5.1 towards the end of the log. I've got my CombFT good but I'm not sure why those are like that.
Please give advice....
You can read how CombinedFT calculates what it displays.
v3combinedft [ECMTuning - wiki]
Also, it looks like you're logging your wideband (LinWideband). Here's more on the AEM wideband and how to get it as close to your gauge as possible.
aemwb [ECMTuning - wiki]
If you want to get picky, your AirflowPerRev is a bit high. You can watch the link video on fuel trims to help get that dialed in.
http://www.ecmtuning.com/demos/fueltrim.html
On the ALS/Knock tab, I'd suggest bumping your TPS % value up to something around 25%, so as to not pick up phantom knock.
On the ECU Inputs tab, you want to check "Lock rear o2 voltage".
I am running a 2.3 stroker. I thought AirflowPerRev should be around .28?
