2G Idle air control code VS wastegate
Xsvpaintball
Apr 11, 2021
Richmond, Virginia
Hey everyone!
So I have 2 codes reading. It I think they might be related. I have the idle air control code and the wastegate actuator circuit code. Not sure if one is caused by the other. Here are my symptoms:
1.bad surging
2.High idle
3.When letting of the gas on the high the car kinda shutters and my air/fuel ratio bounces to rich
4. Bad fuel economy
I did just redo the intercooler piping and a new recirculating valve. Everything seems clamped good and hoses all look connected. I did have the idle air control valve replaced back in august.
Any input would be amazing! Thanks!!
Do you still have the ISC/IAC and BCS (wastegate solenoid) installed?
Can you measure the resistance of the coils in each. The ISC/IAC has four coils and BCS has one.
Why did you replace the ISC/IAC back in August? Where it's coils shorted. What did you replace it with?
The common point that I know of for these faults are shorting out the drivers in the ECU. That can be caused by a bad solenoid, by water in the connectors if they are hanging loose, or by pinching the wiring harness.
Would you please fill out a profile so it's obvious to everyone what car you're talking about when they read your questions. I'm assuming these are for your 99 GST Spyder.
Yes, I have the solenoid installed. It may just be old. I replaced the Idle Air Control Valve because of the surging thinking that may fix it. I’m thinking I could just replaced the solenoid and be good. And yes this is the GS-T
I just unplug it and start the car again to see if it stops surging. Or get a basic code reader to see what the tps volts are.
I have a reader so I’ll start there. What should it be at volts wise?
  • For sale 1g 1G Eprom ECU
    1G Eprom ECU $185 + shipping & paypal fees* great for someone with a 1G or GVR4 who wants to...
  • For sale 1g 1G Ortiz Center Vent Dual Gauge Pod ( discontinued )
    1G Ortiz Center Vent Gauge Pod $100 + shipping & paypal fees* long discontinued * gauges are...
  • For sale 1g 1GA Clear Corner Light Set
    1GA Clear Corner Light Set $65 + shipping & paypal fees* all mounting tabs are intactYou...
  • For sale 1g 1GA Talon Grill ( Great Condition )
    1GA Talon Grill $55 + shipping & paypal fees* Great Condition !You must be registered to see...
  • For sale 2g 2G OEM Door Handle Set ( includes seals )
    2G OEM Door Handle Set $55 + shipping & paypal fees* includes both seals* found a flaw on...
