hx35
smichaels88
Jan 2, 2013
paw paw, Illinois
Ok guys here's the thing, I've done alot of reading about the hx35 on a dsmand haven't got a clear answer. I have a hx35 8 blade and i want to run the twin scroll turbine housing that is on it, no biggie right. Well i just bought a tubular manifold off a friend not knowing anything about the manifold and tried to bold the turbo up to it. The turbine housing is hitting the block and need to come away from the block about an inch. So what I'm asking from all of u that have done this mod is, what brand manifold will position the turbo to clear the block and everything else. I've already dented the water pipe and I'm also wanting to run an external wast gate if that helps. Thanks!
