HX35 what Header?
mechanix565
165
Apr 19, 2009
Pawtucket, Rhode Island
so my question is can i run a standerd 4 into 1 header with an undivided t4 flange on an hx35? isnt the turbine housing a divided flange? will it make any difference if i run an undivided header flange into the divided housing or will it be fine ?
ya me too but that wasnt my question. my question was after looking at the specs of the turbo i linked where would that spool on a stock compression 6 bolt with 272's and an undivided header.
Sure it will spool up. Yes it will work with a open manifold..... Now, when it will spool up and for how long it will last is anybody's guess. But I suppose if you cared about any of those things you wouldn't buy a knock off POS :)
Wow my friend picked up his 7blade 35 for 250. He also snagged a rebuilt pro 52 for 450. You should really put some effort into looking for deals because a real used holset can be had for less and will outlast that china junk.
....and the answer is none of us can tell you because we have no idea what gear you'll be doing this test in, how much boost you'll be running, how much timing you'll have right at the onset of boost, what your AFR's will be, the length and diameter of your intercooler piping, or whether or not you have any boost leaks or pre-turbine exhaust leaks.
This thread is as close to bench racing as it gets. Closed for bench racing and lack of searching on the initial question.
