Hx35 t3 turbo
There is a ton of hx35 variations and as far as i have ever seen they are all T3 as long as they are in original housing.
Theyre some great turbos. Can easly take you into some good numbers, i say 450-550. This turbos are made for heavy equipment such as cummins engines so they are built to last. Im currently running one. Pulls alot harder than my friends turboed Z06 vette (; im bot sure on a rebuilt kit, i say anywhere from 250 and up
Considering the Vette is not much heavier than our cars and starts with an (underrated) 505HP at the crank NA if we are talking about the LS7 Z06.. which is already more than most HX35 owners are going to make, this is definitely exaggeration. LOL
Must be Noob Tuesday.
Holsets have gone up quite a bit since they gained popularity.
Hes only heavier by 400 lbs LOL, im fwd . He also has about 150lbs on sound system . And youre right 505 @ the crank which is right around 480 to the wheels.
Hes running 5 lbs making 530 @ the wheels. I was running 38lbs on a twin scroll set up, i was @ 589whp but e85 is sorta expensive here .
Im now making 485whp. I was seeing 28lbs by 3500rpms on my 2.3 stroker .
60 hp makes a huge difference , specially since my car is about 500 lbs lighter than his.
By those numbers he looks like he's running your old t25.
You can still find the hx35 for 300-400 but it takes some searching. There are other holset turbos that are less popular that can be found for 300-400 as well. Do some searching. I got my hy35 for 200 and had it rebuild for peace of mind. Can't go wrong with a Holset.
Ive seen them on forums not too bad even one that needs to be rebuilt, grab some rebuild parts. Ive seen them around 300.
You want me to believe a high compression 7.0L engine picked up ~10whp/psi? ROFL
You mean 50whp @ 5 psi ? Believe it or not its true. He could be running a lot more with with bigger injectors and a good tune. Those are his only restrictions...... plus he is only getting 12 mpg on highway and im still getting 22-24 .
Z06 are amazing tho.
Most stock Z06's I've seen put down 450-460whp on a dynojet.
As for the OP I'd say $400 in good condition with a stock housing.
50whp @ 5psi is 10whp/psi, :thumb: :aha:
I wouldn't pay more then 600-700 for a good used hx35....
Guys down in FL are selling used hx35 all the time for 300-350.I got my rebuilt one im running now for 350 n was basically new
