T3 turbo any good?
If you're on a budget, go with a 14b or 16g setup. I would skip on that ebay setup personally. You could still run stock boost levels with either setup until you get the required fuel and tuning additions to turn things up a bit.
That's a waste of money. That cheap eBay turbo is junk. You will have to put in some work to make that fit, fab a downpipe, work out the intercooler piping. All for a junk turbo. Buy a used 14b or 16g that will truly bolt on
If I were you, definitely I wouldn't.
As for the kit in the link, you will need some modifications and fabrications. Such as you need to fabricate an O2 housing with the flange it comes with the kit. You can't use the velocity stack since you use a MAF, etc etc...
Within the same budget, you can get some nice 14b or 16g. Definitely it will be better than the eBay kit. Would have less of a hassle in installation, better performance and more reliability.
Gotta give them credit, you get a LOT of crap for $360.
Basically everyone agrees, get a used Mitsubishi 14B or 16G setup. Avoid Chinese turbos, you'll just be buying again shortly after.
If you want 20 lbs of junk with a compressor housing, turbine housing and some hardware. Seems spendy for those parts tho. Just busting your chops :D
We have a resident turbo guru that can always fix you up with the proper upgrade for your needs, he does a lot of work for a lot of us and is very reliable and good at it! @JusMX141
He is the man that answers the questions in our ongoing thread "Questions for Justin" :thumb:
Marty
IF you like nice paper weights I would think its a good option. A bit overpriced for one though L O L
