Jdm bov, any good? (hks replica)
yea but for $40 if figure id give it a shot until i can get a nicer one.
Buy an evo MR or 1g bov for $40. Do not use fake ebay BOV's. Also - companies that make those cheap fake parts drive the real performance companies out of business.
Those HKS knockoffs suck! As well as the greddy knockoffs.
I'm all for EBAY parts and have tested many to help the community. Just do a search on ebay parts and I'm likely there posting on them. I'm definitely an advocate for ebay parts.
But these bovs just don't last. I had the exact same SSQV v1 replica above there, and also with the type-s knockoff.
The Type-S knockoff is prone to diaphram ripping which everybody knows about. So we thought lets try the HKS copy. Well, after a while something was acting weird, all fluttering. We disassembled it and you will see the "diaphram" that separates the chamber between where the vac nipple is and to the main valve ripped and thers really no easy way to replace it because its adhered on somehow, and when its ripped, its ripped. No way of just replacing it like the knockoff type-s.
Only way would be to patch it up, but that is reallly ghetto and not a for sure fix.
So if there is a knockoff to be had, get the knockoff type-s because WHEN (and its not a matter of if, definitely when) the diaphram rips, at least you can replace it with an authentic one from greddy making it a usuable valve still more than half less than the real one.
If you are looking for cheap..
get 1g bov, OR if you have a 2g and dont want adapter flange or piping, just get EVO 8 or 9 BOV.
EVO 8 is plastic but can hold 20lbs prob more. EVO 9 I believe is the steel one and can definitely hold 20+.
Some people are saying they get the ebay ones until they can afford real ones, well if thats the case just do what I said above with the 1g or EVO valves. If you are being cheap until you can afford a real setup, you are spending more TIME and money getting the proper adapter flanges or ic pipes for those hks or greddy knockoffs. the evo 8/9 valves are installed same stock pipe.
the ebay one really doesnt hold boost my friend matt had one and his car was acting crazy until he changed it
exactly....Ebay parts are sketchy, some brands work perfectly, some are just crap...If your willing to take the gamble, go for it
what are the disadvantages of not recirculating?
Search "venting" if you need to.
