can i run a HKS bov without any issues wit the MAF?
You need to recirculate it. Your engine/ecu are expecting the air it releases. Your engine will run bad/rich and You will stall out a lot. They should make an adapter that allows reticulation. If not, you will need another way around it like. Gm-maf and maft.
Sent from my Desire HD using Tapatalk
  • Wanted 6 bolt NT water pipe
    • chrisman287
