Can I run 20psi?
Shamrokk
82
Jan 24, 2011
Hattiesburg, Mississippi
92 Gsx. 2g maf, hard intake, 550cc injectors, 3in downpipe and exhaust. Stock 14b turbo, stock intercooler and plumbing. No way of logging or tuning. Can i safely run 20psi of boost? I know a stock system can only suppoty 16psi, but how much extra does the 550cc injectors afford me?
I don't know...can you? Try it out and let us know how it works- if something breaks then it obviously didn't go so well.
In case you missed the point- none of us can tell you what your max safe boost level is if you're not competent enough to own a logger. ;)
Without being able to log and monitor a/f ratio's, knock and timing it wouldn't be wise to run to psi. I would find a cheap palm on ebay, buy or make a cable, and download mmcd.
