How much boost can I run with evo 560 injectors
Autocrossfwddsm
Aug 8, 2010
San Clemente, California
How much boost can I ran with evo 560 injectors with a small 16g with the neccesary supporting mods
like 16-20ish? Play with it and find out!
I have mine set at 16- but I know of people running 20psi with 560's with a 190lph fuel pump. With a stock pump with a rewire you don't want to push anything over 15-16
Get yourself a logger and find out :)
You shouldn't be playing a guessing game with your engine. Sure you have bigger injectors but are they tuned correctly to give yourself enough fuel without knocking or causing you to run too lean.
To add to the last poste, I once ran 26psi with stock 450s.
It was a 13g and guess what it didn't blow. You will get different results with the 14b. You will get even MORE catastrophic results with a 16g. . . Boost is relatice and arbitrary. Get the logger and find out where your setup runs out of injector when you've triple-varified there are no boost leaks.
Thanks for the good info guys,getting my logger/safc2 very soon,if I get a walbro 190 pump do I need a Fuel pressure regulator?
