how much psi can i hold
Status
Not open for further replies.
xM3RKNUx
33
Dec 7, 2008
ROCKVILLE, Maryland
my car is stock i was just gonna put a evo blow off , front mount, 650cc injectors and safc II ### is the max psi will i be able to run safely and an estimate of the hp i will be around
Try reading the rules, and searching. Way too many variables to answer that correctly.
You will need to get a fuel pump and rewire it before you go much over stock. Is this going be on the 14B?
You will need to get a logger and a wideband to tune as well.
Well im guessing you have not searched since there is many topics on this.
First is maintainence and then im assuming you have a 14b turbo? Well the 14b maxes out at around 21psi. With all supporting mods, that you have listed, adding a walbro 190 fuel pump with a rewire kit and a good tune you can put down some decent numbers. Search.
Oh god, please let this guy be trolling and not an actual person asking a real question...
Status
