will a hx35 from a cummins truck work?
97-gst
1,234
May 16, 2010
Radford, Virginia
Just makin sure it will work tue same on my car as does one designed for gas engines? Also anyone know what all i need to buy to switch from 16 to this
We put one on my buddy's 1g and I wish we hadent, it was any thing but easy.
I've heard of people running them and making good power, but yeah conversion if you don't know how (and you definitely should look at that install guide above) can be pretty rough for sure
Yea man.. Had you even searched the slightest bit the keyword "hx35" you would have had pages full of information.. Including :
http://www.dsmtuners.com/forums/turbo-system-tech/362444-holset-turbos-faq.html
which has a link to this http://www.dsmtuners.com/forums/turbo-system-tech/145691-holset-turbos.html and 8 other Holset specific threads.
Oh and this one, http://www.dsmtuners.com/forums/turbo-system-tech/313476-holset-turbos-results-only-complete-installed-systems.html
But to answer you, it will work.. Will it be cheap? Not entirely. You could either go with the BEP .55 a/r housing and use your stock manifold and down pipe. You'd still need a wastegate.. Or, you could keep the turbo's stock 12cm housing and buy a T3 exhaust manifold and have to make a custom downpipe and still need wastegate/s.. There is also A LOT of reading to be done on your part about your specific oil feed and drain situation..
