how to replace oil pan
yeiko
Jun 19, 2010
edison, New Jersey
i know this question has beens asked alot but i cant fnd a good forum about it.. i was wondering if anyone can explain how to change oil pan gasket step by step
I have a 1997 talon awd tsi
And lastly, Napa sells Chilton repair manuals for 21 bucks, thats 21 bucks well spent, its a great reference and you need torque specs to do a lot of jobs. Good luck
how do you Remove drivers axle bracket from block? thats the only problem im having. do you have to actually remove the whole shaft out ? or ?
Use a pry bar to free up the axle. Make sure you don't puncture the seal in the transmission when you do this.
Didn't read the whole post at first, to remove the bracket from the block you remove the 2 either 12mm or 14mm bolts (pretty sure they are 12mm). Reach behind with a rather and possible a small extension and take em on off :)
When you put your bolts back on, make sure to not mix up the longer bolts with the shorter ones. If you put the longer bolts on the timing belt side you'll shred your belt.
