TheFlashDSM
Supporting Member
- 1,106
- 356
- Feb 18, 2010
stony brook,
New York
i have dsmlink v3lite how do i get horsepower and torque to show under displayed values???
What in the setup needs dialed in to get the HP/TQ estimate accurate?If you dial in your setup correctly it can be a very accurate estimate.
Quote from Dave on ECMLink concerning airflow calculations using SD.Slightly off topic, but how would one calculate air flow in lbs/min from a simple SD log, such as one from mmcd or similar loggers.
Remember that VE is actual air volume divided by the total piston-swept volume over two revolutions for a 4 stoke-cycle engine. Given an accurate VE obtained from the SD VE table (based on rpm and absolute manifold pressure), air volume per revolution is easily calculated from engine displacement. Air mass per revolution comes from applying air's standard density and intake manifold pressure (absolute) and temperature according to the Ideal Gas Law. Air mass per minute comes from multiplying air mass per revolution by rpm.
Dave
I know how to get accurate HP/TQ numbers,
Im no pro with link, but dont you have a to insert a couple of values to get an estimate, such as vehicle weight. I know there's a couple others
. So no, it works without entering any external values such as weight.
Wait, what? Even if this was accurate your math is a bit off, 15% of 327 is 49 = 278^ Nice! It would be safe to assume your around 300hp to the wheels. I don't think DSMLink takes friction into consideration which is ~15% loss with an AWD drivetrain.
Sounds like you got it to log then? Now you need to make a few changes to get WHEEL horsepower. Again, go out to the car and connect to the ECU and start a log (F12). Double click HorsepowerEst and enter 0% for drivetrain loss, this will get you close to wheel horsepower however, make sure the values you have entered for vehicle weight, speed calibration, and RPM settings through the gears must also be accurate for your car. Once this is matches your setup the HP/TQ still won't be accurate unless you do your 3rd gear pulls on a flat level road, this will get you close.
