How to build speed density cable
Rudie4
43
4
Apr 25, 2011
Riverside, California
Can somebody direct me on a how to for making a gm speed density cable. I have all the parts just want to know the wiring thanks in advance
IAT uses sensor ground and the IAT pin from the stock MAS, and MAP uses sensor ground, +5v, and baro input from the MAS. It doesn't matter which wire goes where on the IAT, and the MAP wiring will depend on whatever MAP you are using.
2G MAF in a 1G TEL/GVR4
I want that cable I just need to know how the wiring is I have all the peices I need to make it
