How to Bleed your HLA's (lifters) 👍
I have a good friend and family member that didn't know about this so while I was working on 1 head, I had my son video me bleeding an HLA so all can see how it is done.
Pops ✌️
Does the FSM say that? I just don't trust not having spongy HLA's to start out. Sure they pump up, but they don't butt valve heads, which I have had happen, ONCE.
Thanks for the comments, "cheater" ROFL
Marty ✌️
It's more what it doesn't say. Note there is nothing about bleeding them after, just getting all the air out.
From the 91 3000GT FSM Volume 1 (We use the same HLA's as the 6G72 DOHC)
Nice addition to the thread Steve! 👍
Thanks!
Well Steve, I used the 3000GT method and I will say, flushing them in diesel fuel (I happen to have some on hand for a brush pile fire) works GREAT. It lubes and cleans. I still "bled" the liquid out but boy did it do a good job on old parts that you would think aren't good anymore.
I appreciate the additional info you provided!
Marty ✌️
Marty ✌️
I concur. Spongy HLA may rattle for a minute or two but that's it. Much rather hear that than valves hitting pistons.
I always install the lifters pre bled submerged in a cup of oil, and pumped hard prior to install. I’ve never had issues with lifter noise
To be technical you didn’t bleed the lifters in the video, you drained them of the oil and now you have to wait for oil flow into the head to fill them which will cause lifter rattle on the initial start.
Bleeding them to me means you are removing air from the lifters to fill them with purely fluid, just like bleeding brakes. In the video you are draining the lifters
To each their own. Most folks understand the concept, which is all the video was for. Those were old and dirty lifters as an example for a family member to see so he understood HOW to release the pressure from the HLA's. We talk on the phone, not here, so he gets the rest of the explanation and doesn't end up with more bent valves.
Do whatever makes you feel good and prevents engine failure. 👍 I always leave mine spongy. They pressurize right up when the engine starts cranking and making oil pressure.
For those "AI" guys, I added a picture of what it will tell you if you ask about "bleeding a lifter" on an engine. Trapped air will compress, trapped liquid will not.
Marty
Marty
I'm going to agree with Marty. I've seen a valve hang open first hand from lifter that were not bled down. Oil, not air. I was taught this from a mitsu mechanic. I watched him start up fresh set and as you stated it made some noise upon first startup. He revved it for a little bit and it all settled down as it should. Every motor I've built and every lifter I've installed from a top end rebuild etc or just maintenance did the same thing. It isn't a big deal. To me a hung open valve is a big deal.
I’ve seen multiple occasions of the lifters never filling and cars taking up to 50 miles to properly fill the lifters
I’ve seen multiple issues of the rocker arms coming off of the lifters because there is no tension on them when installed. The car starts and the rocker pops off the valve and due to the unfilled lifter, the rocker falls out of position
The lifters provide the tension for the rocker arms to ride the camshaft, there is no reason or explanation for a hanging valve due to the lifters being properly filled with clean oil. The camshaft is what puts the tension on the rockers and then the valves. Once the valves are filled with oil they do not release pressure and when removed they are always hard and prefilled
My gripe with this method is it should be called draining the lifters and not “bleeding the lifters”.
I’m not trying to change opinions on the topic, however this “dry lifter” method advice for a novice is not something I would recommend
I usually build 2 a year and have for many years. I've never had the issues you have seen multiple times. ✌️ Even if I had, a rocker is a easy fix, a bent valve is not an easy fix and I DO recommend this if you are rebuilding one.
Everyone has there way but I don't sway on this and technically they are called Head Lash Adjusters or HLA's not lifters, as they don't lift anything.
+1, I always install them spongy on every motor I've done, they quiet up in a couple minutes and never had any value train issues.
Same. Stick a small Allen wrench in it to open the valve, give it pumps until I can compress fully by hand. Do it in or over a container of fresh oil so I can watch all the black sihit come out. Install into head.
They go silent after a short drive and stay that way
  • For sale 4G63 6 Bolt Oil Pump Pickup ( great condition )
    6 Bolt Oil Pump Pickup $65 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G OEM BOV Hose ( great condition )
    2G OEM BOV Hose $25 + shipping & paypal fees* great conditionYou must be registered to see...
  • For sale 1g 1G OEM BOV & Vader Cap
    OEM 1G BOV & Vader Cap $45 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 1g LSD 4 Bolt Rear Differential
    1G LSD 4 Bolt Rear Differential $250 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2g front bumper corner brackets
    2g front bumper corner brackets. One pair and one right side bracket only. $25 and $12...
