holset hx-40???
my98gsx
Supporting VIP
794
290
Aug 14, 2005
Wappingers, New York
Im trying to see how this is even possible - was looking on craigs list for dsm parts and came accross this;
763 HP 585 FT LBS TQ Mitsubishi Eclipse GSX AWD
Car claims to have 763 whp and 585 tq... on a holset hx-40 ( with 38mm tial ) I am not at all up to date with my holset info, but is this even possible??? :hmm:
All this "claimed" power using a stock evo mass air as well?... something does not add up here...
I'd like to see video or dyno charts. I'm not saying it's not possible because the turbo definitely can do it, but the Evo MAS is only 3" I.D. so I'm not sure how much intake restriction can exist.
This thing's knocking on Curt Brown's backdoor if it's for real.
763 HP 585 FT LBS TQ Mitsubishi Eclipse GSX AWD - $15000 (cold spring)
Up for Sale is my 97 mitsubishi eclipse gsx awd car is fully built , with a fully built motor and trans car should be good for 10 second passes at the drag strip. car makes 763 hp and 585 ft lbs tq. This car is my daily driver and has oil changes every 3000 miles. car has 7,000 miles on the built motor.
price is 15,000 obo
Mod List
- 2.0 99 Split Thrust Block
- Hot Tanked, Decked, Bored .020 Over
- Wiseco 8.3:1 Pistons
- Eagle H-Beam Rods
- Micro-Polished Uncut Race Balanced Crank
- ACL Tri-Metal Rod, Main, Thrust Bearings
- ARP Head Studs
- MLS Head Gasket
- EVO III High Velocity Head
- Crower Springs/Ti Retainers
- Viton Valve Seals
- Forced Performance FP2 Cams
- Gen 3 Lifters
- SS Exhaust Studs
- Balance Shaft Delete
- Balance Shaft Sprocket Delete
- New OEM Oil Pump, Waterpump, etc
- New OEM Gaskets Throughout
- New OEM Timing Belt
- New OEM Pulleys, Belts, Tensioners
- Magnus Polished Sheet Metal Intake Manifold
- Magnus Heat Barrier Intake Manifold Gasket
- Taper/Polished N/T Throttle Body with Turbo Seals
- JMF FIAV Bypass Plate
- Victory Racing Front Mount Intercooler (Spearco Core)
- 2.5" Stainless Intercooler Piping
- Greddy Type-R Blow Off Valve
- Custom Stainless T3 Ram Horn Tubular Manifold
- Polished Tial 38mm Wastegate
- Holset HX-40 Pro Turbo (60mm 6 Blade Wheel)
- BEP T3 .70 A/R Exhaust Housing
- 3" V-Band Stainless Downpipe
- 3" Stainless Thermal R&D Catback
- -4an Stainless Turbo Feed
- Function7 Restrictor
- FP Return Line
- EVO III External Oil Filter Housing
- Earls 13 Row External Oil Cooler
- Earls -8 AN Stainless Lines
- Forced Performance 4" Intake Pipe
- K&N FIPK Filter
- EVO8 MAS
- Magnecore 8.5mm Wires
- NGK BR8ES Plugs
- Custom 1g Aluminum Racing Radiator
- 1g Upper Rad Hose
- Gates Racing 170* T-Stat
- Power Enterprise 1.3 Bar Rad Cap
- Spal 13" 1710CFM Slim Fan
- Eprom ECU
- DSMlink V2.5
- Civic battery w/ replacement warranty
- RC 1000cc Injectors
- Walbro 255lph HP
- Fuel Pump Rewire
- -6 Stainless Tank to Rail Fuel Lines
- Shepard Stage 4 Transmission
- LSD Rear Diff
- Driveshaft Shop Axles
- New Endlinks, bushings around
- Quarter Master Twin Disc Clutch
- PTT Aluminum Flywheel
- New OEM Throw Out Bearing
- Custom Shift Fork
- Prothane Solid Motor Mounts
- B&M Short Throw Shifter
- Symborski Shift Bushing Kit
- JNZ Underhood Delrin Bushings
- New Clutch Master Cylinder
- New Clutch Slave Cylinder
- Lotek Triple Pillar Pod
- AEM Uego Wideband
- AEM Tru-Boost Controller/Gauge
- Autometer Oil Pressure Gauge
- TSW Snetterton 18x8.5 Rims
- Red Gorilla Lugs
- Falken Ziex 912 Tires
- Koni Yellow Struts
- Ground Control Coil Overs
- Eibach Springs
- Ingalls Camber Kit
763awhp 585ft/lbs should be good for 10s? does anybody else find that funny? LOL
Almost as funny as 1000cc injectors and a single 255lph pump flowing enough fuel to make almost 800 horsepower.
Isn't the highest recorded hx40 car like 680ish? Even though the compressor maxes out at 70lbs/min mid 700whp seems just out of its reach... 1000cc injectors and only a single wally 255... I am not familiar with race gas set ups but even with race gas that seems a bit far fetched.... I could be wrong..
yeah I was actually giggling about that after I read the whole post haha. screw it im going back to a 255 and some 1000cc injectors haha
Ok this guy is really bsing, this guy was snow drifting with my friends a couple nights ago and he said he was making about 450ish wheel.
I should contact the seller and tell him that if he can provide dyno sheets and a video of the car making his claimed horsepower (c'mon, you mean you didn't shoot VIDEO of that event?!?) that I'll lay down $15,000 in cash for the car.
The probability of this car actually making 763whp has about the same probability of me having $15,000 in cash laying around; just as the probability of the car actually being worth $15,000 has a direct relation to anyone actually paying that much for it.
LOL the car is not even that clean my 1g in cleaner than that-floor looks like a sand box.
i was thinking the same thing. its not very clean at all
people can say anything now a days, i mean paper takes ink! i need a dyno sheet and a video of the pull.. to pay that much
The next time I see the guy I am going to ask him for a dyno sheet and see what his reaction.
laser92DSM - when is he going to be at dunkin donuts again? i havnt been up there in about a year but this spring if the car is around i wouldnt mind checking it out LOL. He didnt have much to say when my buddy showed up with his 1g the other night. ( if he is putting down 450whp, he would have some stiff compitition against my friends talon ) but the gsx kid kinda just snubbed him and walked away from his car.
To be honest I am not sure when he will be there next, but ill let my friends know if they see him at dunkin I am going to post it up on here to see if any body wants to meet up with him. Im sure he will be there in the spring.
