dacowgod
Supporting Vendor
- 459
- 287
- Feb 3, 2006
Morgantown,
West Virginia
Just thought I would make a post. I JUST finished up my 2.4 stroker build.
The engine is G4CS, 2.4 crank, Eagle Rods, Wiseco .020 over 8.8:1 pistons, 1200cc injectors. BC 280 Cams, Ported polished head w/ valve job,on PUMP w/ Meth etc etc etc.
Turbo is HX40 pro in the BEP .70 AR housing and the ERL manifold.
Currently I have only ran about 200 miles on it and they have been hard but not brutal as I'm breaking in a new clutch, and new tranny in the same process.
I am running at wastegate pressure which is 18 PSI and let me tell you this thing is lightning.
My last setup was a 2.0 w/ a PTE 6031E in an .82 AR T3 housing and it put 457 AWHP down last season.. at 35 PSI on pump w/ meth although full spool was somewhere around 5200 the turbo design is not nearly as efficient as holset.
Results of the 2.4 and the HX-40 at 18 PSI. FEEL impressive to say the least.
The turbo is full spool close to 4,000 RPM. The over all setup is so much more responsive than the 2.0 was and my plans are to at least double the boost after break in.
I would venture to say the car is just as fast as my old setup right now, and the potential is far greater...
I Just thought I would make a post so people looking for Holset w/ Stroker info that need a resource can contact me. I found alot of speculation on how the Holset would respond on a stroker, but very little when it came to people who have actually done it.
. All i can say is the ERL manifold is a perfect piece, Fitment is excellent in a 2g, I cant believe how much room still available with such a large setup its perfect.
in these pics the engine is wet because its raining out
