HELP with Turbo System/BOV
9TalonNT6
43
Aug 10, 2006
Sacramento, California
:dsm: I recently picked up a 90 GST for 400 bucks which isn’t bad, I've had pervious 1g's. For some reason I cant hear a blow off from this car, Now I know it is a re-circulated system, so its not going to be very loud, Neither do I expect it to be although my pervious first gen I could hear the blow off, and ob my buddy's Laser I can hear it also, Both cars are stock, I checked my turbo and it has little shaft play and spools up fine, the only thing I’ve done to the car is the BCS mod. Any help or info will help thanks.
If the car is completely stock you wouldn't hear it. I know that the 2g had a tube that ended right in front of the compressor and you couldn't hear it. I'm almost postive that the 1g has a very similar set up. Also the recirculating tube on the 1g is really long so it would insulate the sound that would be there.
Havent gotten a Boost Gauge yet, but the stock inaccurate boost gauge shows me between the 7psi mark and the 14Psi, so im guessing 10. Whats the metal line mod?
