Justin DuBois
DSM Wiseman
- 3,400
- 3,375
- Aug 15, 2019
Oakland,
California
I think the knock sensor is akin to an audio microphone. The signal is very weak in terms of voltage modulation. Not something you can measure with a multi-meter - maybe an o-scope. Honestly I've never spent time trying to intercept or put a switch on one. I also think the ECU is signal filtering for its version of the sensor - 1G for 1G, 2G for 2G. Someone here has probably tried different combos.I'm thinking the IAT input might not work at all for this, because maybe the knock sensor voltage is ac rather than dc. So then an ac voltmeter might be more like what you'd need (Vac on a multimeter). I can try to check this out sometime in the next week or 2 here on my car. I still have the ecu+ that made my old logs, and I'm going to run the knock sensor wire to it again pretty soon. When that's going I can see what the Vac and Vdc scales on my multimeter read on it - if either one of them agrees with the ecu+ which for sure has a proper input for this voltage measurement.
