SAUBIK
5+ Year Contributor
- 218
- 188
- Feb 27, 2020
Bratislava,
Europe
Hi, i have EDM spec GS 4G63 N/A rebuilt and turboed. Transmission is F5M31
My idea was to fit LSD to transfer the power of 300-350hp to the front wheels, so I opened transmission, checked, if all things inside is fine and changed the stock open diff with OBX LSD - so here started the path - NO speedo gear, little different shape than stock, but new bearings fit, so outer diameter in place for CV joints is the same but I'm not sure about inside.
Here is the question and help needed - I had problem to move out axles from the stock diff and now when I finally tried to fit axles to trans in car and trans, they are too much loose and when move the wheel in the air, I hear skipping splines and CV joints are so much loose and moving up and down and after few turns they jump off from the trans and it make 1 cm space, so if I fill the trans, it leak all fluid away, so I didn't fill it.
It's possible, OBX need a bigger inner CV joint with more splines? I didn't measure it and backward I look to the photos and I see little differences what I didn't seen then.
