Help with tranny
C2autoinc
Nov 5, 2003
This is for my friend... he has a 1g talon. Had a n/a 6 bolt built up (.20 over, pistons rods...) and blew up the n/a tranny... i had a spare turbo tranny laying around so put that in along with a n/a clutchnet special order clutch. The starter is not catching the flywheel and i notice that the turbo tranny bellhousing is bigger, so i;m guessing we need a turbo flywheel? the second question is will he then need a new clutch and pressure plate? Thanks for all the help, tryin to get this done quickly
Thanks
Chris
Considering almost 70 horses different, you will probably will roast the stock n/t clutch pretty quick if you are prone to hard accelleration.
The starter is not catching probably because you used an awd flywheel in a fwd car?
I would start there. If this is the case, pull the trans and get the right flywheel.
Good Luck
