HELP rpms Drop when clutch pushed in!
DSM Chase
778
52
Sep 19, 2011
Senoia, Georgia
Ok i have 98 GSX, The problem is sometimes randomly mabye 1 time when i drive it for about 30 minutes, When push the clutch in to down shift or am making a turn in nuetral my rpms will drop and she will die. Other times it drops to like 400rpms and then they go back to 1000 (dsmlink idle setting) and i also have a brand New shep stage 3 trans, Clutch, T case, Slave cylinder. Even before i got these parts it did this.
It runs fine, pulls hard at 20PSI, shifts smooth, So i dont think its walking?
^^ Not a bad idea to check those, but I can't say I've had either give me these exact symptoms.
It doesn't sound like you've actually checked too many things yet. Go ahead inspect your hydraulics and harmonic balancer and then do the wonderful deed (it's not actually too bad) of removing the oil pan and checking for play. That is my preferred method, but a harbor freight dial indicator should save you from getting so dirty.
What flywheel, and is it new? My 3g does this frequently, partially because I'm using a Fidanza lightweight flywheel and the other reason is that my MAF is bad.
How would the FW effect it? wouldnt it being lightweight make it easier to idle, if not idle higher?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
