2G vibration when clutch is pushed in
Sounds like the timing tensioner could be bad or the tension wasn't set right for the timing belt . when you push on the accelerator it's putting a small load on the tensioner and the noise will go away . then come back when you let off the accelerator. and if you loose rpms when you step on the clutch you might want to check the engine for crank walk. just a few things that come to mind from your discription.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
