DSM Chase
- 778
- 52
- Sep 19, 2011
Senoia,
Georgia
I have had this problem now for months... I cannot figure it out all my link numberes are good. When the clutch is pushed in while changing gears or at a stop light the rpms will drop, Also when i rev it up and let off the gas it rpm drops.... sometimes even shut off
. My ISC motor tested good all coils at 29 OHMS...
Also my BOV is resirculated...
7lb lighter than stock flywheel
simulating idle switch on LINK
Link idle setting at 1k
battery at 13.5v
TPS is at 0.68 at idle and 5.0V at WOT so its good?
ECMLINK Log file.... Its towards the end of the log i am driving down the road and then when i go to turn into my driveway when i pushed the clutch in it happend... Im going about 13MPH when it happens drops to around 400-500RPMS then shoots back to 1000...Log is at the bottom In the Attached Files..
Quick video of it rev RPM dropping, does same thing with clutch in or in neutral
RPM Drop ISSUE - YouTube
. My ISC motor tested good all coils at 29 OHMS...Also my BOV is resirculated...
battery at 13.5v
