rpms drop alot when engaging clutch
Deadly BlaZe
1,890
5
Oct 2, 2004
Alpharetta, Georgia
is it normal for the rpms to drop really quick when holding down the clutch because i've read somewhere that it's not supposed to do that. if its not supposed to do that, what could be causing it?
First of all, your thread title and your post are conflicting.
Your rpm's will dip when you engage your clutch because you are applying a load to the engine.
engage = letting clutch out
disengage = pushing clutch in
From what you're saying, I would say yes its also normal for your rpm's to drop fast when you put your clutch in. why? because 99% of the time, when your clutch is in, your foot is off the throttle..giving your engine no reason to be revving - therefore dropping your rpm's to idle and fast.
Maybe I've completely misinterpretted your post though.
Yo, deadly... from what I can understand, 'cuz yes, your post is a little confusing... it's completely normal for your RPMS to drop when you engage the clutch. Perhaps you should look into a good aftermarket clutch so you can shift quicker. Two other suggestions: a lightened flywheel will help those revolutions jump right back up there, and if it's an important race, you can learn how to shift while leaving the gas down. Heh, although I don't recommend the last suggestion unless you are prepared to pay dearly for new transmissions. ;) I'm on my third.
thanks for the help guys, n yea it answered my question. sorry about the weird wording, but u guys got what i meant.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
