clutch plates grinding when engaging
mike1999
150
Jun 10, 2005
oakland, Maine
i just installed a spec stage 3 clutch on my car along with a remanufactured tranny, after breaking the clutch in for 500 miles (50 miles more than the 450 mph specified) now when the clutch is engaging but only when it is under load not just at idle, it seems as if the clutch plates are making a loud grinding noise. anyone have any idea?
i had the master cylinder replaced no more than a year ago so that wouldnt be the problem i wouldnt think anyways. Maybe the slave cylinder but the grinding happens when i slip the clutch, but i can slip the clutch a little and it wont grind. Still slave cylinder? thanks for the info guys
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
