Spyder Help diagnosing intermittent knocking sound issue
jb705
4
Jun 22, 2022
INWOOD, New York
Hello all,
99 spyder (4g64 SOHC). I replaced the drive belts recently and within a few startups, noticed an intermittent knocking sound coming from the camshaft/water pump area. The noise is like two pieces of wood knocking on each other and it comes and goes. When the engine is hot it seems to do it less often. I am adding a video for reference.
Solution
Not sure if this is the cause but harmonic balancer is wobbling. Inspect the rubber in the middle. They crack and the halves separate. This can cause major problems WHEN it separates. I wouldn’t start it until you fix this.
Solution
I have been suspecting the dampener because of excessive movement so i am just going to replace it asap. Will report back if that was the issue.
